my speedometer quit working yesterday on my sled after i hit a jump, i tested the cable its fine, the speedometer works its the square drive that is under the secondary clutch, anyone have any ideas how to fix that i go no idea.
Sconnie
Check the how-to section. Bet your driveshaft bearing is bad on that side. They're very prone to going bad, and the speedometer key shearing there is a perfect indicator that that bearing is going south.
do i have to take the track off to replace that bearing and how bad would it be to run it like that for the rest of the season?
the bearing on that sled can be replaced without pulling the track.If you losen the track and feel inside the tunnel you can tell if the bearing is off center if it is it is toast if it is not then replace the speedo adapter and try it also make sure you grease that bearing recularly.
ok ill do that, wheres the grease fitting for that bearing, only grease fitting i saw was on speedo adapter.
