Looks like the speedo and cable work but the adapter below the secondary clutch isnt spinning?
Is this is common? on 94 580zrs?
when the spedo quits it is usually a sign that you have a bering out on the drive shaft. check those then there is a key inside your spedo drive that tends to snap. cheap fix.
It could just be the key. They do go for no reason sometimes.
