When it started, my sled (Yamaha Phazer) would run until it got good and warm, about two miles. Then it would lose one cylinder. Shortly after that, it would quit.
I changed the fuel pump, fuel lines, new vacuum line from crankcase. It started, ran about ten minutes, and quit.
I pulled the plugs and they were wet. I changed the plugs and it ran a few seconds.
This morning I put new plugs in it and it wouldn't even fire. I removed the balance tube between the carbs and added a little ether. It ran until the ether ran out. the plugs look dry.It's not getting gas, but I can't figure out why.
