older twin 500 rotax engine goes full throttle on its own any suggestions i found crank case has a bit of a hole in it beside fan shroud could that be the cause im open for suggestions
Suggestions? Try some punctuation - it'll make your posts easier to read.
Yes, a hole in your crankcase will cause problems. A two stroke engine needs a sealed crankcase for it to work properly. Any idea what caused the hole?
