I have a 2009 skidoo MXZ TNT 500 ss. The electric start does not work, band new battery, press the starter button and nothing. I can pull start it no problem and the reverse works off of the starter button once it’s running no problem. Solenoid and relay next to the battery and all the fuses around the battery compartment are all good. Also, I’m not sure if it’s related but the dash fuel gauge doesn’t work either. Any ideas?
Welcome!
I would simply start unhooking all the connections and clean them each one at a time!
Most likely you have a bad ground?
Measure the voltage on either side of the solenoid. If the solenoid is not even clicking, then there is a different issue. Something in the wiring from switch to solenoid. This is also the circuit that has the fuse.
