1 - 10 of 10 Posts
I have a 1999 Arctic Cat ZL 600 that I got this summer. It has half a tank of gas in it right now. I am going to put seafoam in it for the first tank.
Should I just fill it up the rest of the way with new gas and the seafoam, or should I siphon the old gas first and then add new gas and the seafoam?
SUMMER SUCKS!
Yea I would just use the seafoam and the new gas mixd with the old. Also, where do you get seafoam? I would like to put some in my sled for the first ride
King of the Universe
If it were me, I'd suck the old gas out (put it in my truck) & start with a fresh tank. Give yourself the best opportunity for success!!
Thanks everyone for all of the help. I appreciate it.
I got the seafoam at Gander Mountain. Meijer also usually has it, but there we out the last time I was there.
I also would remove all the old gas out of the tank and than add fresh, this new(er) gas(ethanol) that we have now days does NOT last for more than a month or two
I agree. The SeaFoam works wonders. That with some new gas and you'll be fine.
You can get SeaFoam at any auto parts store. Really, just about anywhere nowadays.
I did the same... we started by just adding gas, dont do that it sucks because it didnt work! just run the old gas through your truck or something then put a fresh tank of gas with seafoam and your good to go!!
Anytime gas sits in my sleds for more than a month, I use a siphon and drain everything out that I can. And then I throw in iso-heet with about a gallon of race gas, and let it run.
Probably doesn't do anything beneficial, but I FEEL like it made a difference ;)
If the sled isn't EFI, not only drain the gas ( I use an electric fuel pump) Remove the carbs and clean them! EVERY SEASON! Best preventive maintnace you can do! A partialy pluged jet will melt down the engine!
1 - 10 of 10 Posts
