The other day I went out and was working on my 2000 Polaris sport touring 550 with extra 10 susp. I was rejetting it and getting it ready to ride on Monday. I noticed that the rear end was really sagging. I picked up the rear and held it for a few seconds and let it down and it bottomed right out. I looked at the rear shock and it looked as though the oil all leaked out of the shock. I do not ride this sled much, it is my wife's, so I ordered a new "cheap" shock from Dennis Kirk. The new shock came in tonight. The new one pushes in and I have to pull it out. Is this right. It seems to me that I should have to push really hard to push it in and it should push itself out. Is this not my problem with the saggy rear end? I wonder if I didn't either get the wrong shock or just a bad one. Tech support is closed through the weekend, so I am turning to my friends here. Thanks
Live to ride
I just put a new shock in my extra 10, and it did the same thing.
Just get push the rear of the sled down a few times and eventually it should work fine..at least mine did
were you able to push and pull the new shock? shouldn't it push back out?
Live to ride
after the shock was I got on it and kind of bounced on it I guess you could say and it wasn't coming back up, but after a while of pushing down on the rear bumper it seemed to work fine.
The springs could also be shot?
Rocky Mountain POW!
I'm not familiar with that particular shock but I am with shocks in general. I think the shock you have may be a non gas charged shock as opposed to a gas charged shock. A chraged shock would push itself back out and a non charged shock will just dampen. I would look towards the springs being shot as they are what controls the ride height I believe.
Dumb A$$ attack
Headea back out the the garrage that day to look at the situation a little better in the daylight the next day. Cheched the springs all over and the shock. Pondered for about 10 minutes over the deal, then it hit me. I had put some small 4X4's under the skis whial I was working on it a couple of days earlier. The raised front end was putting a lot of pressure on the rear of the sled. It was just enough. The problem was hiding right in front of me in plain sight.
Rick
yes if it is a oil shock it will do that. after a nice ride it will work like it should.
