New to sleding. '96 Storm 800 idles at 2500RPM. Suppose to be at 1600RPM. How dose one set the idle on ?
Thanks in Advance
should be bigger black nobs you can adjust on the carbs to bring the idle up or down, just look clase at the carbs, should see them towards the top. Just make sure to do each one the same, its a tripple right?
Yes it is a triple, Sorry for being so dumb? Are they on the side of the carbs ... I thought that those were for lean and richness. I will look for black ones tonight. Thanks again....I am not that familiar with 2 cyc stuff use to working on old cars.
Thanks again....
There are small ones kind on the side/top (angled) for the air mixture. The idle ones are on the side and are much bigger than the bleeds. THey are almost like knobs on some Mikunis.
