I have a 01 MXZ 600, that i can't get the cluth bolt off. I belileve i have cranke bearing problams but, the clutch bolt broke loose then seized back up within a fraction of a inch. My question is, What do you do if you break the clutch bolt of or, strip the crank. I belive the heat from the bearing may have welded them together.
Thanks for any help.
I would seriously take your sled into a dealer and let them work that out for you. Sounds like you have a tough problem to tackle in the garage, you may also need some tools that only the dealer has. Just an idea, I know your probably looking to save some cash, but I would trust my dealer. Good Luck!
