Hey everyone i am just thinking about taking appart my secondary and replacing the spring and buttons and stuff and giving it a good cleaning. But when i tryed to get the thing off it just woundnt work. I cant figure out how to do this. If anyone has any info on how to get the secondary off when it is seized on there I would be forever in debt to you(only if it works).
Removing Clutch
If you have the clutch with the 3 bolts to adjust the clutch sheaves.Take out the bolts and use a 3-way puller to remove the clutch.Use something to protect the threads on the end of the jackshaft.The clutch should float on the jackshaft once you get it off grease the jackshaft and inspect yearly for freeplay.The clutch by polaris specs should have about 1mm of free travel back and forth on the shaft.This is to prevent binding
