My sled is pretty un responsive, replaced a few motor mounts and carbs are perfectly tuned. my problem is with my 1991 arctic cat ext 550 i ride trails with many hills at about 800ft above sea level. i have stock clutches but i have a yellow spring. I know i have clutch problems with my brand spanking new belt because at a stop the belt squeaks at the primary once i do get going i can get amazing takeoffs sometimes other times it hesitates or bogs
I suspect several clutching problems such as buttons or the slides or spring or idk but i did clean the clutches and sand down the sheaves (the clutching surfaces)?
am i using the wrong spring color for my setup and is there anything im missing?> any input will be appreciated
