The torx screws can be a bugger, use good quality bits. A hammer impact driver is also sometimes necessary, or a little heat to break the loctite. It's common to strip the torx heads.
The helix often needs gentle persuasion, I use a dead-blow hammer to tap it. Like 05xcsp said, nothing comes out at you. Removing the helix will give you access to the roller and spring area, but you won't be able to separate the sheaves until you remove the c-clip. I use a clutch press from SLP, it works pretty slick. You will need to get the Team adapters for their regular press. A good set of correctly sized c-clip plyers is nice, too.
