2001 Ski Doo Formula 500 Deluxe
Hello All,
I recently purchased a new sled which is a SkiDoo Formula 500 Deluxe. At first I didn't notice but now I realize that it runs 1000 rpms higher than it should. For example before the clutch catches it must reach 4500 RPMs. At speeds around 80 kmh/~50mph it is running at around 7000 to 7500 RPMs. What should I do to fix this?
Thanks All,
Jack
Also, what does your drive belt look like? A worn out belt will need higher RPM to engage and will not run as fast at full throttle.
