Lost all power to lights, gauges and hand warmers. Starts and runs strong, reverse works. 2005 Rev 800, no battery or electric starter. Only found 2 fuses, they test good. Verified all wiring plugs intact and tight, that I could find.
Any Ideas? No repair shops in my area...
Thanx for your Time (time=money)
Cheer's Mike
up under your dash there should be at least two black ice cube relays I would start by checking them. If you have a napa dealer in your area they can cross that relay over and get you one much cheaper than a dealer. otherwise get a manual and check the output of the stator and go from there.
Thanx for the nod Gentlemen,
Just checked the headlight bulbs, both have good continuity. The cube relay is possible, I may try the new parts ave to see. Looking at my repair manual, the stator testing may be difficult. Wondering if a bad regulator could cause, seems like it would not run.
Yappy Holidaze, Mike
