1 - 14 of 14 Posts
yamaha 440SS
1983
im gunna try and replace the seal tonight with out splitting the case.. is it possible...???? flywheel side..
need help asap...
dave
hmm crankshaft is abvout 3" long dont have socket that will pit over that..... i didnt get it out yet, any ideas for removing it..
eags
yup i got that bastard seal out, now im looking to find out what sealant to use around it if any ??????
eags
yes it is, doublelip.. i figure id just install it was a coat of spray oil on it or something... thanks
lastnight i tried to install the crankseal, i didnt hve much luck, there is a ridge in the mddle of the seal that is making it hard to get in there... is it possible to install this seal with out splitting the crankcase...
eags
Discussion Starter · #10 ·
no **** eh.. thats brutal....
what else should i replace once the case is split, i guess i will need to pull the primary off too then huh ??
dave
Pull the clutch and replace the other seal while it's apart. Get some good sealant to seal the crankcase halves when you put it back together.
I know there's a shop near me that will pull the clutch off the crank after you get it out for $10. Pretty cheap to me...
Discussion Starter · #14 ·
clutch needs to remove before i can split case, there is part of the frame body in the way, the crank goes through it it sucks..
1 - 14 of 14 Posts
