Edge motors are pretty easy, especially the fans. Remove the pipe/can, remove the two front nuts, remove the back nuts (2, maybe 3). Lift the engine without disconnecting the throttle cable or oil/fuel lines, it should give you enough access to tighten the nut on the bottom of the steering column. You shouldn't have to remove it completely, just move it enough to get a wrench on the bottom nut.
