7.1.2.crew!
im kinda new to this snowmobile it was given to me as as long as i maintain it..
i have a 1996 formula z 583 rotax rave. i have to replace the recoil starter because i couldnt get it to retract ... i bought a used one and not sure if there is a specific way to install it back on.
I cant remember but I think that one has just four bolts(10mm heads), rather than the recoil with the band stretching all the way around it. These ones are simple, just pull it on and the other one pretty much just bolts right in. You will feel it slip into place. As long as the recoil is against the motor good you can bolt it back up.
7.1.2.crew!
also what the difference in the formulas the skidoo makes for 583.? like mines a formula z and i know theres several others
