I was wondering if track tension has any effect on the suspension stiffness? I was having problems with my sled bottoming out quite often. I am a husky guy but I have never had a problem like that. So last night I moved my rear suspension down to the lower holes to jack the rear up. I found that I got a lot of slack in the track. I tightened it till it was about the right deflection. Now,does the track tighten when the suspension is compressed? I just don't want the track to be too tight as it was fine before I moved the rear bolts. Suspension doesn't seem to bottom out any more. Shouldn't it still be bottoming out but it's just a higher ride? I am not sure if this is anything to worry about or not. Any info would be appreciated.
