I have a 1998 Indy Sport and the rear suspension springs are weak as the machine bottoms out on the littlest of bumps. I was wondering if there is anything out the normal i should do when i go to replace them, settings, etc...
thanks
You can turn that block the short end of the spring is sitting on to the highest position for a little more tension..
Thanks for the last post. I always thought that there was only two positions for those blocks, but on closer examination I found that the other end was higher yet. I'll let you know if it helps.
