1 - 1 of 1 Posts
Just bought this sled, and right off the bat it seems to have the TSS problem. It seems to cut out for a second when you let off the gas and then try to give it more gas it cuts out. So I want to bypass this. I guess I am going to first just unplug it (open circuit model right?) and see if it goes away. If that corrects it then I just want to bypass TSS and not the whole kill switch and everything, so I just put shrink tube on the middle pin and plug it back together?? Can you get the shrink tube off again if down the road I want to replace the switch or something? And does anyone know which harness exactly is the correct one, as there are many on this particular sled.
Thanks very much!
1 - 1 of 1 Posts
