i was wondering if peak 50/50 antifreeze would be ok to run in my el tigre 6000, i have heard its only good to run arctic cat antifreeze but i am just wondering if there is any difference between arctic cat and car antifreeze so i can use it. thanks
A 50/50 mix of any ethelene gylcol anti freeze will work just fine. Just don't mix OAT antifreeze (Dex a Cool type) with regular glycol types.
is peak 50/50 a ethelene gylcol anti freeze?
Peak, like Prestone, make all types of anti freeze. If it says long life or lifetime formula on the jug, then it's probably an OAT type (usually red, orange or yellow in color). If it just say antifreeze/coolant and is green, then it is common ethylene glycol.
The only difference between Peak green stuff and Arctic Cat green stuff is Arctic Cat makes the profit on the Arctic Cat green stuff. Use any brand you like, ethylene glycol, 50/50 or 60/40. 50/50 will protect down to -34 F. I don't know about you, but if it's that freaking cold out, I'm inside drinking hot cocoa or something!
