i have a 95 zr580 it had a pipe on it and the needle setting was changed. I took the pipe off. Very loud. I changed the needle settings back to stock. Now it wont start unless you hold the gas wide open. It did not do that before. Any help would be great. Thanks...
Administrator
Check the throttle position cables from the carbs to the throttle... if they are not hooked up correctly, it won't start unless the throttle is depressed. You may have loosened one of them when you took the needles out... pull 'em apart and clean 'em and see if that helps...
i had the same problem if its carbed the pipe kit has differnt needle slides than stock it also had biger main jets (mine came with the sled) you need the stock slides im running 350 jets and 50 pilot jets might be of some help
