Just replaced the Skis on my A/C Crossfire R1000. Did not adjust any thing just replaced the skis, crabides and rubber dampner blocks..... they look aligned and it seem to track fine. Just wondering if there is something else I should be doing prior to heading out.....
Thanks.....
You can simply use a tape mesure and either mesure inside or center to centerand see where they are pointing! Some say to toe out about an 1/8" I toe in about an 1/8"!
Heads Toe Out Wins
Both of you have given me good advice in the past.... Flipped a coin and it was heads so I will try 1/8 out first!!!! Thanks will let ya know when we get snow again!!!!!
:rolleyes:
