Is there a trick to changing a fuel primer on a Arctic Cat 400.
I have bought a new one and tried several times to replace it and it’s still leaking fuel. Help
Welcome
Can you post a pic of where it is leaking?
It most likely is an add on.
There should be a 1/4 x 1/8 T in the fuel inlet line to the fuel pump.
Then there could be a spacer between the carb and intake for it to pump into engine.
I believe (?) the center line from primer goes to carb and the side goes to the fuel line
