Ok so, I just got done putting a 5" riser on my sled, to do it I of course had to get an extended brake line, and a throttle cable extension.
Contrary to what someone said on here, I got an extended brake line from SLP with the 90 bend flange and it fit perfectly. So that was good.
I got the powermadd throttle extension and that's where I ran into a problem. With it installed and the in line adjustment screwed in as far as it will go, there isn't enough slack to let the engine idle, it holds it open just a little bit. Before I put it in it idled at about 1800 rpm, now it idles at about 2500 rpm. I screwed the adjustments on top of the carbs in as far as they would go, or it would be idling at about 4000 rpm which is just about when the clutch engages which is bad mkay? When your sled is sitting in a driveway pointed at the highway and you start it and it darn near takes off on it's own.. it would've been a bad day.
Anyway, I'm just curious if anyone has any little tips to share with me on where I might be able to get a little more slack on the throttle lines to let it idle at it's usual rpm.
Just to be clear, the carb and in line throttle adjustments are in as far as they will go, so am I screwed?
