Will pipes off of a 97 xcr 600 sp fit a 95 xlt 600 sp with xtra-10 suspension.
Thanks for any help.
I don't think so.I asked that same question when i had my XLT.I was told that the XCR is a case reed motor and the XLT is a mono block engine.
Any body else care to take this one.
i have a 95 xcr and on the engine it says XLT. If there is somthing like a number that I could check for you I will do it if you let me know where to find it.
1996 xcr600sp, polaris changed the body style to the agressive
style, along with motor to case port, It will not fit the pipes are different.The XLT body style is different.
Sorry. Different engine and chassis. Starting Line Products probably still makes after market tripple pipes for that sled. You'll have to redo the clutching and jetting thou.
