I am having a problem with the low beams on my 2001 XC SP Polaris.
The bulbs appear to be ok and also work on high beam. I inspected each bulb and they each appear to be ok. The filament appears ok (not blown) on both bulbs . Does anyone have any tips for troubleshooting headlight problems? I don't want to buy a hi/low switch if that is not the problem. Thanks
My son's 2000 has the same problem; however, his lo beams work and the brights don't. It also now has no dash lights. All bulbs are good. I'm about sure that it's the switch.
its your switch problem is all your power runs through that switch so if the high beam part goes bad on the switch you will have no lights which is no fun at night.switch is pricey to
