The choke lever activates a cable that goes to a bracket between the carbs. To adjust the cable, you need to loosen the two locknuts on the adjuster and turn the adjuster until there is 1/8" to 1/4" of slack from the choke lever to the nut. Retighten the locknuts. One adjuster does both carbs.
