1 - 13 of 13 Posts
Well, finally got around to mess with this a bit. Decided to go ahead and do some cleaning. One thing I have a problem with is that it doesn't seem to have much power and doesn't want to idle at all. I guess I will have to get a carb kit and clean it out. Seems to run fine once the RPMs get up there a bit but it shure doesn't like taking off. Any ideas what I should do with the idle issue let me know. Messing with the idle and mixture screws didn't help anything. It also smokes like a cheap cigar. I know the previous owner did dump the old gas and put fresh in but I don't know what mixture he set it at (and should be be what 40 to 1?) or what sort of 2 cycle oil was used.
before pics
After I cleaned it up and re-striped it and installed a new windshield.
Carb probably just needs to be taken apart and cleaned well. The idle problem is probably just a plugged pilot jet. The sled looks in great shape. I would check the cranks seals as well with it being as old as it is.
Vintage Sled Pilot
Nice piece of old iron!!! Glad to see another sled resurrected and another vintage fan! Is it going to be a rider?
Yep, just something for my boys to jump on if we ever get enough snow. If I can get it to idle right then I can check to see if I have a seal leaking.
Discussion Starter #7
OK thanks. If we get some snow this weekend I will try to snap some pictures from my camera. These above were from my phone and they dont look too good.
Have another question. The guy I bought it from said it ran fine but the track would slip in heavy snow. I looked at it pretty good when I was cleaning it up but the track looks great. I took the chain case off and it too looks fine. Could it be that the track is stretched and may need to be tightend up or something? When I ran it a little yesterday it didn't seem to have a problem. But, when I bought it and was loading it on the trailer I thought I felt it slip.
Break out the duct tape..
Sled looks great!:thumbsup:
1 - 13 of 13 Posts
