is the srv motor the same dimensions as the phazer 485?
is the 540 air cooled? i have a phazer chassis just woundered if the 540 is the same block etc... thanks
i am not certain that it(540) would fit between the frame rails , as the phazer engine is stuffed in it's frame pretty tight , if you have ever had to pull off a recoil starter, you would know where i am coming from !
after doing a little research it looks like the 540 in a older srv is fan cooled , if thats the case the frame rails (width) and engine mounts would be the deciding factor.
I've tried that no it wont fit! The phazer is narrower! But we were working on a 2000 Phazer, which had the mount on either side.
