1 - 20 of 23 Posts
I see service manuals, but i need a parts breakdown for rear suspension 92 indy 500 efi.
Click on the link below for service manuals, Click on Polaris then go to 1985-1995 and that will be your service manual, that will help you in the long run.
Also Polaris Browse works for part numbers to help you search, plus it breaks them down individually which I think is what you are after.
thanks, I was already in the service manuals, did not locate what I needed. great stuff for sure.
I am looking to find / purchase a solid bar in the rear suspension in the track area, one end by the springs. I do not see it in the parts breakdown for the suspension either. Any idea what it is called?
Look at the site Coolhand posted. Look at the "Suspension" link. The shafts are 16, 17, 18 and called "shaft, pivot arm or shaft, rear idler."
I think that's what you are asking for. Good luck, the Polaris diagrams are not very intuitive.
The bar i need is not shown in that suspension link diagram. It is not 16, 17 or 18. I will get under it for a picture this weekend.
Discussion Starter #7
65085
65086
65087
65088
These are photos of the broken bar I need to locate and get. As others suggested it is a XX suspension. Any help would be appeachiated
IF you are talking about those bars and the bars that are encircled together those are springs for your suspension. They don't attach to anything. The top part of it sits on this part from the link below.
You see the blocks in that link as well where the top of the spring sits on it, the bottom sits next to the rails.
Kimpex Part # for the left is 04-384-01, Right part # is 04-384 you can get them cheaper on eBay or amazon
Discussion Starter #9
Between the two springs there is a remnant of a bar misding the middle highlighted in the bottom two photos, that is what I have concerns with
At any rate get the skid out and then look at it.
Plan on going to the swap meets and pick up a Xtra10 complete with Fox shocks and put it in!
It looks like that bar he is showing is what is left of the shock. In looking at the E Bay photo, that is what it looks like to me.
I agree with Cool Hand and KC. Time to pull the skid and see what you need. It may be easier to just get a used skid to put back in. That skid is a rusty mess. It also looks like the one cross shaft is worn out in the last photo. It is not sitting centered on the washer.
  • Like
Reactions: Ryunker
What would be "the skid"? Where to start to remove it?
That is what we call the whole rear suspension. You would loosen up the track at the rear wheels. Then remove the 4 bolts in the side of the tunnel that hold the suspension in the tunnel.
Discussion Starter #16
It is out, got a guy texting claims to have what I need... Craigslist
I like babbits because you get an idea of the price of the parts as well as the number. That can be helpful in decision-making. Too bad Polaris doesn't do that. It would not be difficult to post the "dealer" retail price so you could see it.
Trust me as someone who worked with Polaris software they don't always post the dealer prices for us either. They were hit and miss with that really bad back in the day. They finally got their act together a few years ago. And even then sometimes they will show only what you are supposed to charge not what dealer cost is which would drive us crazy because certain people we dealt with we would give discounts to because of the amount of business we did with them throughout the year.
1 - 20 of 23 Posts
