my friend just picked up 1999 xcr 440 temp light keeps coming on and coolant level is always empty we tried nto get all air out of system but still no good when we took water pump out we seen that a metal seal was in pieces but on this sled the oil pump is mostly all in one with water pump could this get costly and has anyone had this problem thanks:dunno:
over heating 440
he said it was leaking arond where the thermastat would be and he fixed it but if u take each line off and blow in it fluid will pus out of other tubes witch im assuming is good but part is still broken in pump i think head gasket went also cause took y pipe of and feels stiky like coolant on exhaust ports :dunno:
overheating 440
well we are going to fix it now but at first we thought we had to split motor to take out whole unit but we dont just some new seals and impeller for hope that will solve it just wondering if this sled was known for this:dunno:
