Hello, I have a 1994 Yamaha Ovation 340 my daughter rides. It is oil injected however the oil pump does not seem to be working as the oil reservoir level is not going down. I noticed this and pre-mixed some gas so she could continue to ride, I mixed it 32:1. I read a post on this formum about bleeding the lines with the bleed screw on the pump and did that but it did not solve the problem. Is it ok just to continue pre-mixing the gas or since its oil injected will that mess up the carbs? Also if it is ok to just continue to mix the gas with oil what would be the recommended ratio? Or any other tips on fixing the oil pump.
Thanks very much.
Gary
Thanks very much.
Gary
