I've got a `79 Scorpion whip 440 TKX and would like to change the 30 year old gear oil.
Anyone have a good how-to info and oil recommendations?
s/t
There is no drain plug in that case, so you will have to either clean up a mess, or tip the sled on it's side and remove the cover. You can then soak up the oil with rags, or use a suction device to remove as much as you can.
Refill with 8-10oz of the desired lubricant.
I would use SAE30.
