Putting my 98 skidoo form 583 deluxe back together and I'm having trouble getting the o-rings that go on top of cylinders to stay put. Any suggestions/tricks? I'm talking about the 2 o rings that go around the top of each cylinder.
I use a bit of grease to hold 'em in on the sleds I have played with that have them... I'm not sure on Skidoo but on some of the Polaris sleds, it helped to buy the OEM O rings as the after-market ones were just a tad small and would pop out of the groove, even with the grease holding them in.
If you use Vaseline on them and then just work them with your fingers and stretch them a bit as you are lubing them them work!
I've stretched them and I've used gasket goop to hold them in place. Both work just fine. But BC_Dan is correct, OEMs fit better, if you can find them.
  • Like
Reactions: rvroman969
I ordered a gasket kit when I did the top end, yeah prolly not OEM parts.
I've tried stretching the O rings as well as heating them in hot water, with marginal success. If the O rings are close, that may give you a chance to get it together without the ring jumping out of the groove when you put the head on. I was working on a 650 and eventually tossed the after-market O rings and bit the bullet. The OEM ones went in smooth as silk with no muss, no fuss. I don't think the after-market pays as much attention to the exact dimensions as the folks that make the OEM rings.. just my opinion, mind you.
Good luck, it can be really frustrating!!
Thanks, I found some oem o-rings so not going to try to mess with the aftermarket ones anymore. It is very frustrating.
