I recently purchased a 71 Moto-Ski Capri with a 340 JLO Rockwell motor it turns over good but has no spark I tried cleaning the points and replacing the points any ideas??
Your 1980 Moto Ski was basicly a Ski Doo as Bombardier bought Moto Ski in 1973 and by 1976 all Moto Ski's were using Rotax engines and ever increasingly more and more Ski Doo made parts.Could be the condensors....they both went on my 80 MotoSki
Before you swap anything out, try unplugging the wiring harness at the engine and see if you have spark. If you don't then the problem is in the engine. If you do, then it's in the wiring somewhere.yeah i disassembled the kill switch and unplugged the keyed ignition no change what else could it be
he already tried that.Before you swap anything out, try unplugging the wiring harness at the engine and see if you have spark. If you don't then the problem is in the engine. If you do, then it's in the wiring somewhere.
