I have a 1977 Sno Jet SST 440. I Can't figure out HOW to get the lights working the Voltage Regulator Checks out good, there is an ignition switch on this but not the original the is NO HIGH and LOW light switch( I assume it is that) on left side of handlebar. I was told the lights could be wired DIRECT. I forgot to say there is a STUPID circuit board on this too and is checked to be good. The tach and speedometer lights also do not work. Can this be wired direct? If so how can I do that? ANY HELP, MUCH, MUCH appreciated
