1 - 9 of 9 Posts
Hey guys I'm having trouble getting this sled to run. When I suspend the machine and give it gas the track will turn .When I drop it to the ground it feels like it's not getting enough fuel because it bugs out and the track won't turn .Any ideas .Thanks
Carbs should be cleaned every preseason no matter what. Even when using non-ethanol gas. Over the summer the gas can get old even with stabil in it. I would drain every last bit of gas out of it, go through the carbs again, replace the fuel filter and go from there.
'93 Phazer and The Kid
Not sure if you started with your carbs yet, if not, warm it up and do a compression test first....jmo. Plugs?
If you have junk in your carb make sure your tank is clean.... Also check the airbox for a mouse nest...
Clean your carbs!
Check your center to centers (10 1/4") (12 1/4")?
Then put a carpenters square across plugs to driven clutch
If anything you want the motor to be just ahead of square on clutch side
So under load it stays square
1 - 9 of 9 Posts
