I just got a 1991 Polaris Indy Trail Classic 488. I have riden it a few times . Maybe a total of 5 miles .It has 1100 miles on it it has a studded track . I had a 79 Arctic Cat before an Eltigre did what i needed to do on that . My question is what should I be doing to the Polaris or atleast checking before heading out . Everything looks good but I would like to make sure any required maintenace is done . I do not know what the previous owners have done to it . Thanks Mike
the first thing i would do is give it some grease, change chain case oil do a bolt check make sure shock is working properly and check ski alignment change fuel and oil filter, blow out oil lines the hit the trails
The chain case is that we `re the reverse lever is . How do I go about bleeding the oil lines Thanks Guys
Mike
On my sled after changing the filter there is a screw on the oil pump you simply leave the cap off the tank loosen the screw and watch til no air comes out yours may be diff. someone will clarify
