i just put a new belt on the sabrecat 700 and its squeeling, my buddys does the samething, seems that with track off ground it doesnt stop turning track, is this the deflection?
????? help me out here, i read and looked at my manual and it for some reason confused the heck out of me, deflection tool???Yes it is! There could be a problem withe the torque stop too tight?
is that the rubber headed mount toward the bottom on the left side? has a jam nut on the threaded part? if it is i just make a.005 gap there? cause mine looks tight now no gap. if not then im really confused, lolThere is supposed to be 0.005" of space between the torque stop and the engine block.
If someone has adjusted this to make up for a wearing belt, putting on a new one will make it too tight.
yep, and as i just found out, if it is tight, it will cause all kinds of weird vibration. I have spent hours working on my primary clutch, thinking that is what was causing it. Turns out having that pitch stop tight against the engine will transmit ALOT of vibration.is that the rubber headed mount toward the bottom on the left side? has a jam nut on the threaded part? if it is i just make a.005 gap there? cause mine looks tight now no gap. if not then im really confused, lol
i have looked threw my manual for over an hour and never found crap about the adj, grrrrrrr cool ill back mine off tomm. we are getting snow so i will be able to run ityep, and as i just found out, if it is tight, it will cause all kinds of weird vibration. I have spent hours working on my primary clutch, thinking that is what was causing it. Turns out having that pitch stop tight against the engine will transmit ALOT of vibration.
At least in the shop manual for mine, it is .05"/1.5 mm of space between the rubber stop and the engine. As long as you can see between it, it should be enough.
ok i found the torque stop was really tight to motor, so i adjusted it to .005 and im still squeling, should it be at .05 or .005? theres alot of diff there. trying to get it right im leaving for munising in the am. thanks for all the help so far guys!!!! still cant seem to find it in my 05 repair manual, unless im looking in the wrong spot?yep, and as i just found out, if it is tight, it will cause all kinds of weird vibration. I have spent hours working on my primary clutch, thinking that is what was causing it. Turns out having that pitch stop tight against the engine will transmit ALOT of vibration.
You have two different issues... The pitch stop should have a gap no matter what. The problem you have is that you have a new belt which is wider than the old worn out one, and have to adjust your secondary clutch. (and yep, .05/1.5mm for my 01 at least)ok i found the torque stop was really tight to motor, so i adjusted it to .005 and im still squeling, should it be at .05 or .005? theres alot of diff there. trying to get it right im leaving for munising in the am. thanks for all the help so far guys!!!! still cant seem to find it in my 05 repair manual, unless im looking in the wrong spot?
i adjusted the stop to .05 and that seemed to do it thanks!!!! my buddy had the same issue with the same results, i love this site you guys are grrrreeeaaatt!You have two different issues... The pitch stop should have a gap no matter what. The problem you have is that you have a new belt which is wider than the old worn out one, and have to adjust your secondary clutch. (and yep, .05/1.5mm for my 01 at least)
it must have been REALLY pushing on it if it was enough to move it! The manual says to loosen the motor mounts, use the torque bumper to push the motor forward until the clutches are parallel, and then back the bumper off.i adjusted the stop to .05 and that seemed to do it thanks!!!! my buddy had the same issue with the same results, i love this site you guys are grrrreeeaaatt!
it was tight on there, his was also. his quit squeling, he runs a 031 belt and mine calls for a 035, i was told they are diff belts but according to the cat guide they are the same except 31 is a harder compound.it must have been REALLY pushing on it if it was enough to move it! The manual says to loosen the motor mounts, use the torque bumper to push the motor forward until the clutches are parallel, and then back the bumper off.
thanks, the belts i got have a white film on them, i will wash the last one and adjust the deflection, thanks for all your help guys!!!you should also wash the new belt before you put it on with hot soapy water to clean off the mold release compound on it
and make sure your pulleys are clean too before installing the new belt
