1 - 13 of 13 Posts
Live 2 Ride
im getting bad battery drain from the winch on my plow bike, anyone have any ideas for a lift solution manual or not but the cheaper the better, i dont wanna pay 300 bucks for am actuator, thanks
my in-law uses his bike to plow ,he uses a cheap winch (harbor frieght tools)
doesn't have battery drain issues , the other guy at work was having battery
drain issues with his better brand (warn) plow though, he went to a better battery (more amps )
(gel filled) has not had an issue since !! just an idea ???
Live 2 Ride
Discussion Starter #8
put a truck battery in a marine battery box+ mount it to your rack, the only way to go when useing a winch.
yea iv rigged up a second battery, used a utility battery worked great
Alex
so does the problem still exist or was that your solution?
If it does persist, why not just put a switch on the battery feed so it can't suck juice unless you want it to.
Live 2 Ride
Discussion Starter #10
yea the atv battery doesn't have the power to run the winch so much so I rigged in a lawn tractor battery that I can charge a hook up when need the extra power
Warn
I have an 04 Kodiak. Not the most powerful bike, but man, can i move snow with it. I have a Warn plow and Warn winch. No extra battery and no issues so far..
Knock on wood. Good luck.
Alex
I think I'm more confused than anything now. Is the winch draining the battery slowly while not in use? (what I was thinking the problem was). Or is it drawing too much load to run off your quad while in use?
If you take the power suply cord from an inverter, you can plug it into the power port and hook it to the mower battery!
1 - 13 of 13 Posts
