hi guys /gals i got a problem with a friends sled its a 98 venture 500 fan and i got a problem with the throttle safty switch is there a way to bi-pass it when i unplug it the engine stalls
if it dies when you unplug it then unplug it and splice the to wires together permanantly... you either need to open or close the circuit. so if it dies with open circuit (unplugged) then close the circuit with a splice
The TORS on the carbs, or the switch in the throttle block?
If from the carbs, just plug the two harness parts together.
just for clarity, when bypassing the tors system, the 2 wires that lead from the bars to the carbs need to be plugged back into themselves. the carb wires dont care. tors is a pretty nifty safety feature and if your not using a safety lanyard, i highly recommend figuring out why your having issues.
