I am stuck on how to get the front axle out of my sxr 700? I have the chaincase cover off and the gears out and the secondary off and the speedo gearbox off, and also the bearings out. now I just need to know how to get the axle out? any help would be greatly appreciated.
thanks
No I dont, do I need to take the whole chaincase out to get that bearing or is there a way to pull it out?
thnaks for the help
There is probably a snap ring, you'll need a good set of snapring pliers if this is the case. You should not have to remove the chaincase. Just remove the snapring and push it towards the chaincase side and it should come right out.
