I have an 88 Wildcat, and the seat is held on by studs on the edge of the seat, if you look under the tunnel, you should see some small nuts directly under the sides of the seat, should be 2 or 3 on each side, they are right up against the edge, so they are a little hard to see. Hope this helps you out.
