So my sled was recently rebuilt. And it suddenly start running poorly and would randomly cut out and shut off. So as an example you would get going 50 mph and then it would slow itself down and once it stop it would shut itself off. I then noticed the secondary was a little lose so I took two washers of and that made it tight again. But it didn't change anything and then it got worse and could only go 30 and then would cut out. I figured it was electrical so changed the ignition coil and the CDI box. Now it runs great but will go 30mph and won't go any faster and runs at 7000 rpms. The spark plugs also look different the side with the clutches is darker and wet but the exhaust side is a lot cleaner and is dry. Was wondering if anyone has any ideas what it could be.
