1 - 16 of 16 Posts
Ok I have finally narrowed it down for my first sled. Its between 96'-98' MXZ 583 or ZR 580. I now a guy who has a shop. He has a 97' MXZ with a clutch kit, new track and plastic skis for$2200. And found a 96' ZR 580 EFI for $1500. Wich is better as far as motor, suspension? Also I don't know much about sleds yet so wich is better EFI or a carb. Thanks
back in the game
EFI is better, though on older sleds it may not be the best thing, since it's much harder to fix than a carb.
Both are good sleds, but I'd go with the ZR :)
I might be a little biased cause I have a cat, but the ZR 580 is a pretty fun sled. The EFI is great as long as it is working right. The ZR's are quick and pretty light but I have never ridden the MXZ 583 so I really can't compare them.
The 96 ZR does not have the ETT long travel and the EFI is not batteryless. You would be better off with the MXZ.
ZR better
ZR580 whith green hood have ETT and batteri less EFI
Many rider here in sweden change to ZR from just skidoo
When i bought my zr600-98 i have the MXZ670-98 i ride them
and ZR WON
thats a 98 the 96 are the old bodystyle and its hard for me to believe that 600 beat 670 mxz cause i saw that match up with my 2 buddies and the 670 won by quite a bit.
My 97 Cougar 550 would give my buddies 97 MXZ 670 a real good run. My 00 ZR600efi was side by side on a tuned MXZ 670 when mine was totally stock. My buddies 98 ZR600efi was side by side with a 98 MXZ 670. The 670 HO's went pretty good but the regular 670's weren't all that much. I was going to reply to this topic yesterday. I wouldn't recommend either sled, the ZR is pretty out of date even compared to the 97-98 year sleds. Alot of changes were made in those 2 years. The 580 was a pretty high strung engine from the factory and I have heard of alot of crank issues. I would look for a 99 ZR 500 or 600 if you could, these sell for around $2000-$2700 maybe even less if you can find a deal. Your not going to get a great deal from a dealer. Go onto hardcoresledder.com, amsnow.com, even check e-bay . You should be able to find a better deal on a sled near your area.
four gear pinned
the firt mxz's are just built cheaply, just look at the primary it looks like its from a sled from the 70s. also the hood and windshild look dumb. Personaly I dont like rotax engines, reeds are way better
1 - 16 of 16 Posts
