Hello again everyone,
Would someone be able to tell me the function of the clutch screws that are labelled 1-6 on the primary clutch. And what I should set them at to achieve maximum performance out of my 2000 MXZ 700?
Right now they are set at 4??
Thanks for your help!
I am not super familiar with the newer sleds (such as yours), but if it is using the Rotax TRA (Total Range Adjustable) clutch, the 3 bolts that you are referring to adjust the "character" of the clutch. They change the engagement RPM of the clutch, the top end RPM, and the backshift reponse. 4 seems to be a common setting. I don't remember which way causes more engagement RPM and I didn't take any time to research this. You can play with them to see the changes that they make. Just be sure to always have all three in the same position.
This might help a little:
http://www.snowgoercanada.com/service_clutch.shtml
HTH
They can be changed to set your rpms on the top end. I would set your top at 8000 rpms. The higher the number the more RPMs you'll get. You can also buy hollow pins that hold the weights, this has to be done when riding in higher altitudes.
