Just got my seat back with the new cover installed. How does this seat mount? I see the ability to put two bolts in the rear thru the tunnel. Is there anything else to mounting the seat?
I see some strap ends attached to the tunnel? Are the relevant to seat mounting?
When I got this sled, the seat was not attached. The new cover was partially installed, but never finished.
I think you machine should have separate seat and tank, with a tank cover as a separate piece from the seat. It's been a long time but as I recall the seat should have a piece that slides up around the back snout of the tank and the tank cover should have snaps to hold it on and help hold tank in place. I usually swap that seat/tank set up for the single 1 piece tank and seat because the old wooden seat platform usually doesn't hold up vert well.
