supa-rider
ill start by saying i put dry gas in my sled but it dose not seem to help... at low speed i seems to misfire or thats what it feels like to me(it almost wants to stall)...it starts and idles perfect.. plugs a perfect color and it runs fine at higher speeds... so what could be the issue here?
misfiring
i had a yamaha 570 that did that it was in my carbs had them recleaned bettrer and did some adjustments on them dont no if this is your case but mabe could help :dunno:
supa-rider
im not very keen on the electrical of these sleds, but its possible that maybe your stators weak causing the sled to stutter when the sleds slow
thats kinda what i was thinking...
supa-rider
also i have a bit of an exhaust leak
well you should fix that leak, could lead to some problemss in the end
and if you can get your hands on a ohms meter, and can test the resistance of all your electronics, then have someone with similiar sled test the same parts, you should be able to detirmine whats wrong, because if the stator or some coil is going to be causing the problem it would be way off when you go to read its resitance
supa-rider
Discussion Starter #7
any other ideas
