Rebuilt carbs. 1 carb leaks fuel from vent on top of carb while running. Does this indicate sticky float?
To adjust hold the carb upright with a piece of fuel hose on the inlet
With the bowl off blow into the hose and raise the float till it stops passing air
This should happen as the float becomes 'Level' with the carb body
If not bend the little tab just slightly, retest
